Hi, I’m looking to for an example project to get started with writing dataviewjs and Templater scripts, i need the types and i haven’t got a clue how how to get setup? Does anybody have an example project i can use as a base :0
Thanks
Thanks
What do you mean by “types” ? ![]()
Did you search out here for topic(s)/post(s) that could give you some leads ?
Although, generally speaking, the documentation of each plugin tend to be a good start
Sorry im looking for a starter pack or something. For vscode when want to create an extension there is a starter project to build upon, that’s what im looking for. But just realized there all their own kind of thing, like dataview and templater are not the same sort or project? so i would have to look at both
I’m sorry but do you want to create your own plugin or do you want to use Dataview and Templater within your notes ? ![]()
If it’s the former, there’s Obsidian’s Developer Documentation, a whole section Developers: Plugin & API on the forum and a dedicated channel on Obsidian’s Discord server too
For the latter, in a very very very short summary, yes, Dataview and Templater do their own thing within Obsidian.
One queries and displays datas from your notes while the other allows you to create “templated notes”.
Read this bit and follow the links (to one or more demo vaults):
