Enable pasting into Accent Color modal in Settings → Appearance
  1. Open Settings, go to Appearance
  2. Choose Accent Color and open the dialogue
  3. Toggle color entry to “HEX”
  4. Delete old hex code entry
  5. Attempt to paste in a hex code for a color
A hex code that I copied to my clipboard will be pasted into the dialogue.
Nothing happens. I’ve tried the code with and without the hashtag. Neither works.
Just ran into this setting up a new vault.
Very minor, but I think this could be considered a bug.
The Style Settings plugin (using the Minimal theme) accepts hex codes pasted from the clipboard.
We’re on hold at the moment with this FR:
