Re-opening a previous thread after update to 1.4.12 as it did not sort this one out
in source mode i create a template with a field as such
created: {{date}}
this used to work prior to the introduction of properties and when the template was applied to a new note the creation date would be added.
Now this is what happens
When the template is applied to a new note, it seems to work. The created property is recognised as a date and the creation date is added (second shot)
Then for some unknown reason, the template is altered (4th shot), and the created field is replaced by a different format in source mode and in property mode no longer recognised as a date when applied to a note and fails to show properly (third shot).
After discussion on Discord, it was suggested that working on the template should be done in source mode only.
thx
r
