I already did some forum searches, so I know there are feature requests regarding these issues, but, honestly, I believe this should be recognized as a bug because it breaks search functionality significantly. The problem I’m describing affects results in both universal searches and when searching inside an individual note.
When searching, I should not need to match diacritics and curly quotes perfectly to see full results. This is annoying, at best, and misleading at worst, delivering no or incomplete results in a way that may not be immediately obvious to the user. This is particularly frustrating when you’re a writer using the Smart Typography plugin or searching quotes saved from books, which almost always use curly quotes and diacritics where appropriate.
Mostly, I believe search should be curly/smart quote and diacritic agnostic or at least be connected to an option for exact or partial matching.
- A search for
cliche
(no diacritic) orcliché
(with diacritic) should return the same results. - A search for
can't
(no curly apostrophe) orcan’t
(curly) should return the same results.
Getting around this problem on desktop can be annoying. On mobile, it’s so frustrating and flow-breaking that I usually give up entirely.
