Has this feature been added yet? I have successfully generated a LIST of notes, which is useful, but it would be even better if I could transclude. Even more so if I could force only transclusion of their first line, or of a specific heading common to all of them.
I came here looking for exactly the same thing.
@Gnopps I found the answer in this comment on Issue #177!! Worked a treat for me!
Hi all,
Iāve been trying to implement a āDormant projectsā list/query. It should give links to files that contain no unfinished tasks with the #next tag. Iāve tried:
LIST from #project AND -#next AND "1. Projects" AND !"4. Archive"
sort file.mtime desc
limit 5
But this sees a project as dormant if there exists a finished task with the #next tag. I imagine I have to do something with dataviewjs, looping through all unfinished tasks and checking them for #next but I donāt know where to start. Any pointers would be helpful.
This is probably nothing new for you, but I love what Dataviewās task functionality enables in my workflow:
Anytime I write something in a random or daily note which is important and I want to keep for later, like a task, insight, idea etc., I can simply make it a - [ ] task and tag it #insight.
Then I have a note where Dataview gathers all these important snippets from all over the vault with the task query:
TASK
WHERE contains(tags,"insights")
SORT tags asc
Iām trying to create a list of all created/modified notes on a specific day in my daily note for that day but with the following code I get a parsing error. Does anyone know what I did wrong?
LIST
FROM "" -#daily-note
WHERE date(2022-06-17T23:59) - file.mtime <= dur(24 hours) and date(2022-06-17T23:59) - file.mtime > dur(0 hours)
SORT file.mtime asc
It says
Expected one of the following:
'and' or 'or', /FROM/i, EOF, FLATTEN <value> [AS <name>], GROUP BY <value> [AS <name>], LIMIT <value>, SORT field [ASC/DESC], WHERE <expression>
But Iām not that elaborate in Dataview to understand what that means in my case.
Topic
Summary
- How to filter by duration?
Test
Summary
- dataview: v0.5.46
Input
Summary
dictionary files
- Location: ā100_Project/02_dataview/Q90_Duration/Q90_test_dataā
- filename :
dic_20020301 - file.mtime: ā2002-03-03T19:30:50ā
Date: 2002-03-01
#Project/P03
WorkoutDuration:: 90 minutes
- filename :
dic_20020401 - file.mtime: ā2002-04-03T19:30:50ā
Date: 2002-04-01
#Project/P04
WorkoutDuration:: 120 minutes
- filename :
dic_20020501 - file.mtime: ā2002-05-03T19:30:50ā
Date: 2002-05-01
#Project/P05
WorkoutDuration:: 3 minutes, 7 minutes
DQL10_filter_by_duration_and_TABLE
Summary
Main DQL
| Code Name | Data type | Group By | Purposes | Remark |
| DQL10 _filter _by_duration _and_TABLE |
F_dur_diff:a duration |
no | 1.To define a field variable F_dur_diff andlet F_dur_diff = date("2002-05-03T23:59:59") - file.mtime;2.To filter by F_dur_diff 3.To sort by file.mtime in ascending order 4.To display the result as a table |
Notes
Summary
The same codes:
- To filter the data by duration
Original Example10
```SQL
FLATTEN date("2002-05-03T23:59:59") - file.mtime AS F_dur_diff
WHERE F_dur_diff <= dur("3 months") AND F_dur_diff >= dur("0 months")
Another Example11
```SQL
FLATTEN (date("2002-05-03T23:59:59") - file.mtime).months AS F_dur_months
WHERE F_dur_months <= 3 AND F_dur_months >= 0
Another Example10B
```SQL
WHERE date("2002-05-03T23:59:59") - file.mtime <= dur("3 months") AND date("2002-05-03T23:59:59") - file.mtime >= dur("0 months")
Another Example11B
```SQL
WHERE (date("2002-05-03T23:59:59") - file.mtime).months <= 3 AND (date("2002-05-03T23:59:59") - file.mtime).months >= 0
Another Example10C
```SQL
WHERE date("2002-05-03T23:59:59") - file.mtime >= dur("0 months")
Another Example11C
```SQL
WHERE (date("2002-05-03T23:59:59") - file.mtime).months >= 0
Summary_code
title: DQL10_filter_by_duration_and_TABLE =>1.To define a field variable `F_dur_diff` and `let F_dur_diff = date("2002-05-03T23:59:59") - file.mtime;` 2.To filter by `F_dur_diff` 3.To sort by file.mtime in ascending order 4.To display the result as a table
collapse: close
icon:
color:
```dataview
TABLE WITHOUT ID
file.link AS "File",
dateformat(file.mtime,"yyyy-MM-dd HH:mm:ss") AS "mtime",
F_dur_diff AS "F_dur_diff"
FROM "100_Project/02_dataview/Q90_Duration/Q90_test_data" AND !#daily-note
SORT file.mtime ASC
Screenshots(DQL10)
Reference
Summary
I am trying to create a Dataview query that pulls in the first, uncompleted task for each file that is marked as a project.
I tried doing the following, but no dice:
TABLE
filter(file.tasks, (t, i) => i == 0) AS "Next Action"
FROM -"Templates"
WHERE
type = "project" AND
status = "active"
SORT due asc
I am getting an error message that reads:
'(', 'null', boolean, date, duration, file link, list ('[1, 2, 3]'), negated field, number, object ('{ a: 1, b: 2 }'), string, variable
Does anyone have any idea how to achieve this?
My goal is to be able to quickly see, for all of my projects, what is the āNext Actionā to take, as determined by the first checkbox on the page that hasnāt been checked.
Hi
Iām trying to add a number of fields together to get a total value for all the fields eg:
Table sum(rows.est) sum(rows.S1) + sum(rows.S2) + sum(rows.S3) + sum(rows.S4) + sum(rows.risk) as PpvalueTotal
where notetype= "#pipeline"
group by "#pipeline"
However if there is more than one instance of the field in a file eg:
S1:: 10
S1:: 20
It does not work - I get:
Dataview: Every row during final data extraction failed with an error; first 3:
- No implementation found for 'number + array'
Also stupid question but ⦠what is the meaning of ārowsā lol? Iāve got this far without being able to find an explanation of what is it is anywhere !
You could look at
DQL20_sum_number_or_list_GROUP_BYin the the following document. -
How to sum up a number or a list of non-groupBy(or groupBy) data with skipping the null value? PS.To sum up one field
- Problems: snowbiker100: Dataview Snippet Showcase Q641 at 2022-06-24
- Solutions: by Justdoitcc partI
Many thanks - that has worked !
One small favour - I donāt quite understand why and what is going on lol !?
Am I correct that there is some sort of problem with ānullā values ?
That mapping function therefore might be ensuring that a zero is returned where otherwise a nothing value might be returned - although Iām not sure why a null value would be returned when adding instances of fields together ?
List all unmentioned files that link to file that holds this dataview query, which havenāt been mentioned yet in the textflow otherwise.
Great for quickly creating MOC files that automatically track and list all files that link to it
list from [[]] and -outgoing([[]]) sort file.name asc
Show all recently created files with outlinks and inlinks
table
file.outlinks as "To", file.inlinks as "From"
from "" sort file.ctime desc
Show all uncreated files (Files that are being linked to in other files but havenāt been created yet) THX @mnvwvnm
TABLE without id
out AS "Uncreated files"
FLATTEN file.outlinks as out
WHERE !(out.file) AND !contains(meta(out).path, "/")
GROUP by out
SORT out ASC
Show all Uncreated files with origin (Files that are being linked to in other files but havenāt been created yet). THX @mnvwvnm
TABLE without id
out AS "Uncreated files", file.link as "Origin"
SORT out ASC
List all outlinks and inlinks of specific file with exclusion of the file that holds this dataview query. (I use it to preview links to and from MOC files one step down the hierarchy)
Files are beeing sorted in the order they appear as links in the flowtext
list from outgoing([[FILENAME]]) or [[FILENAME]] where file.link != [[]] sort file.links asc
Hi Moonbase59,
Great piece of work, thank you very much!
Iāve done some testing and was wondering:
Shouldnāt
date(today).month100+date(today).day = birthday.month100+birthday.day,(date(today)-birthday).year,(date(today)-birthday).year+1) as Turns
be:
date(today).month100+date(today).day <= birthday.month100+birthday.day,(date(today)-birthday).year,(date(today)-birthday).year+1) as Turns ?
BR
Great examples. Thereās not many out there on link analysis. Your post is a treatise on inlinks and outlinks.
Is it possible to do the following:
Iād like to find all outgoing links that appear in all notes in a folder, group by outgoing links with a count for each sorted desc.
Cheers!
Anytime!
It is difficult to explain it.
You donāt need to correct any
nullvalue. All you need to do is use the correct solution. -
It is recommended that you should use the Conclusion in the following document because it is the correct solution.
You could read the DQL10, DQL20 and DQL30.
You may understand what happens in the
DQL20_debug_sum_cash_groupBy. -
In fact, it is necessary to understand the importance of the Conclusion. If you do not use the Conclusion, some notes are not presented in the result.
How to sum up a number, null, or a list of non-groupBy(or groupBy) data with skipping the null value? PS.To sum up one or two fields
- Solutions: Solutions by Justdoitcc
So Iāve come up with this first
TABLE file.inlinks as Inlinks, length(file.inlinks) as Sum, file.outlinks as Outlinks, length(file.outlinks) as Sum, sum(length(file.inlinks)+length(file.outlinks)) as Total
FROM "path/to/folder"
SORT sum(length(file.inlinks)+length(file.outlinks)) desc, file.mtime desc
This will sort files in a folder by total of Outlinks and Inlinks. But the list will be quite big.
TABLE length(file.inlinks) as Inlinks, length(file.outlinks) as Outlinks, sum(length(file.inlinks)+length(file.outlinks)) as Total
this is shortened to just the amounts.
I couldnāt figure out how to achieve your specific request though. But this solution should also give you an idea of āwhat files in a folder are the busiestā. If thatās your goal :).
Hope it helps out a bit.
Cheers
Very cool. Thank you!
Iāll get some learning miles out of your effort.
Hi all, love the plugin! Hopefully this is a simple question, and I just havenāt learned how to fully use it yet. ![]()
I use AidenLxās Folder Note plugin which uses a note named the same as the folder that itās in (see example layout below).
My goal is to just show a list of folders and contents, but not the foldernote itself (the folder whoās name is the same as the parent). Hereās what the actual file layout looks like on disk:
Notes/
Notes.md <--------- (this is a folder note)
Subject A/
Subject A.md <--- (this is a folder note)
Some topic related to Subject A.md
Subject B/
Subject B.md <--- (this is a folder note)
Some topic related to Subject B.md
I write a dataview list query in my Notes foldernote like this:
LIST rows.file.link
FROM "Notes"
WHERE file.folder != this.file.folder
GROUP BY link(file.folder, file.name)
The current WHERE is just to filter out the Notes.md file and only show everything else in the Notes/ folder. So, that will render this in obsidian:
- Subject A
- Subject A
- Some topic related to Subject A
- Subject B
- Subject B
- Some topic related to Subject B
Iām trying to find a way to do something like WHERE rows.file.name != rows.parent.name or something similar.
Any ideas?
Topic
Summary
- How to get the
s_file_parent_nameof a file? (DQL10) - How to get the
parent_foldernoteof a file? (DQL20)
Test
Summary
- dataview: v0.5.46
input
Summary
dictionary files:
- Location: ā100_Project/02_dataview/Q83_FolderNote/Q83_test_dataā
- filename :
Q83_test_data.md
Date: 1990-12-31
### this is a folder note
folder: 1990-03
- filename :
1990-03.md
Date: 1990-03-31
- filename :
dic_19920301.md
Date: 1990-03-01
## input
### milestones
- [type:: "food"] [desc:: "breakfast"] [cost:: 10] #Test/d01 [[Note J]] , [[Note K]]
- [type:: "food"] [desc:: "breakfast"] [cost:: 20] #Test/d02 [[Note J]]
- filename :
dic_19900306.md
Date: 1990-03-06
## input
### milestones
folder: 1990-04
- filename :
1990-04.md
Date: 1990-04-30
- filename :
dic_19900401.md
Date: 1990-04-01
## input
### tasks
- [ ] [type:: "food"] [desc:: "breakfast"] [cost:: 100] #Test/d01 [[Note P]] , [[Note Q]]
- [ ] [type:: "food"] [desc:: "breakfast"] [cost:: 200] #Test/d02 [[Note P]]
- filename :
dic_19900406.md
Date: 1990-04-06
## input
### tasks
folder: 1990-05
- filename :
1990-05.md
Date: 1990-05-31
DQL10_get_the_file_parent_name_of_a_file_and_LIST
Summary
Main DQL
| DQL10_get_the _file_parent_name _of_a_file _and_LIST |
file.folder:a string |
yes | 1.To define a field variable s_file_parent_name 2.To filter by file.name 3.To group by a link 4.To display the result as a list |
1.The āparent linkā doesnāt link to the folder note itself. 2.The Regular Expression in the DQL10 is based on the DQL10 in the following topic. - Solutions: by Justdoitcc |
Notes
Summary
Q: What does the following DQL statement mean?
FLATTEN regexreplace(file.folder, "^(.*/)(.+)$", "$2") AS s_file_parent_name
To get the s_file_parent_name of a file
- In English: To define a field variable
s_file_parent_nameas the expression likeregexreplace(file.folder, "^(.*/)(.+)$", "$2")by usingFLATTEN - In other words:
let s_file_parent_name = regexreplace(file.folder, "^(.*/)(.+)$", "$2");
For example
file.path: 100_Project/02_dataview/Q83_FolderNote/Q83_test_data/1990-03/dic_19900301.mdfile.folder: 100_Project/02_dataview/Q83_FolderNote/Q83_test_data/1990-03s_file_parent_name: 1990-03file.name: dic_19900301file.ext: md
The same codes: to filter by file.name
- To filter the data by file.name where file.name is not equal to
s_file_parent_name
Original Example10
WHERE file.name != s_file_parent_name
Another Example11
FLATTEN split(file.folder, "/")[length(split(file.folder, "/")) - 1] AS s_file_parent_name
Summary_code
title: DQL10_get_the_file_parent_name_of_a_file_and_LIST =>1.To define a field variable `s_file_parent_name` 2.To filter by file.name 3.To group by a link 4.To display the result as a list
collapse: close
icon:
color:
```dataview
LIST rows.file.link
FROM "100_Project/02_dataview/Q83_FolderNote/Q83_test_data"
GROUP BY link(file.folder, s_file_parent_name)
Screenshots(DQL10)
DQL20_get_the_file_parent_name_of_a_file_and_LIST
Summary
Main DQL
| DQL20_get_the _file_parent_name _of_a_file _and_LIST |
yes | 1.To define a field variable s_file_parent_name 2.To define a field variable parent_foldernote 3.To filter by file.name 4.To group by a link 5.To display the result as a list |
1.The āparent linkā actually links to the folder note itself. 2.The DQL20 is based on the DQL10 and SeanWcomās suggestion. |
Notes
Summary
The same codes: To get the parent_foldernote of a file
- Take the file
dic_19900301.mdfor example.file.path: 100_Project/02_dataview/Q83_FolderNote/Q83_test_data/1990-03/dic_19900301.mdfile.folder: 100_Project/02_dataview/Q83_FolderNote/Q83_test_data/1990-03file.name: dic_19900301file.ext: md
Original Example20: The absolute path
the slice of DQL
FLATTEN file.folder + "/" + s_file_parent_name + ".md" AS parent_foldernote
the result
s_file_parent_name: 1990-03parent_foldernote: 100_Project/02_dataview/Q83_FolderNote/Q83_test_data/1990-03/1990-03.md
Original Example21: The absolute path
the slice of DQL
FLATTEN regexreplace(file.folder, "^(.*/)(.+)$", "$1$2/$2.md") AS parent_foldernote
the result
Another Example22: The relative path
the slice of DQL
FLATTEN s_file_parent_name + "/" + s_file_parent_name + ".md" AS parent_foldernote
the result
s_file_parent_name: 1990-03parent_foldernote: 1990-03/1990-03.md
Another Example23: The relative path
the slice of DQL
FLATTEN regexreplace(file.folder, "^(.*/)(.+)$", "$2/$2.md") AS parent_foldernote
the result
Summary_code
title: DQL20_get_the_file_parent_name_of_a_file_and_LIST =>1.To define a field variable `s_file_parent_name` 2.To define a field variable `parent_foldernote` 3.To filter by file.name 4.To group by a link 5.To display the result as a list
collapse: close
icon:
color:
```dataview
LIST rows.file.link
GROUP BY link(parent_foldernote)
Screenshots(DQL20)
Part 1/2
Part 2/2
Fantastic, thank you! Learning more and more Dataview every day!
Hereās what I ended up with:
LIST rows.file.link
FROM "Notes"
FLATTEN regexreplace(file.folder, "^(.*/)(.+)$", "$2") AS parent_name
WHERE file.name != parent_name
This lets me be sure that the āparent linkā is actually linking to the folder note itself. So adding a second variable lets me use both the parent folder name, and the foldernote name.
Thanks!!
