def merge(j, k, l):
cdef:
int j
int N = 2000
float dx, s = 0.0
The syntax should be properly highlighted in Reading View AND Editing View.
The syntax is highlighted only in Editing View and not Reading View.
Obsidian version: v1.5.12
Installer version: v1.4.16
Catalyst license: none
Base theme: light
Snippets enabled: 1
Plugins installed: 0
Plugins enabled: 0
But what surprises us is that sometimes the Source mode and Live Preview provides better syntax highlighting than the Reading view.
Is there a plan to take the best of each and merge them for consistency?
I am pretty sure that we all expect consistent syntax highlighting across the views.
Just for the history sake, I found a similar post and attaching it down below:
Yeah, I was surprised cython wasn’t in the PrismJS supported languages list at all (I didn’t see it). Does it go by another name or is there something similar you could use?
I’m not part of the team, so can’t speak on the development or decisions made.
I have re-checked the support list and no… it is just not there.
The most similar one is of course Python, but it lacks some of the crucial keyword highlighting such as cdef.
I just hope that the dev team becomes aware of this on-going issues on inconsistent syntax highlighting and come up with fixes in the near future.
My understanding is that the syntax highlighting in the editor (Source mode and Live preview) comes from CodeMirror, but I’ve never been able to track down a definitive list of supported/unsupported languages.
