Syntax highlighting for sh code blocks disappears in Reading View
  1. Create new Vault
  2. Enter the following code
```sh
echo hello
  1. Notice that echo is highlighted yellow
  2. Switch to reading view
  3. Yellow highlight disappears
Syntax highlighting to remain.
Syntax highlighting disappears.
	Obsidian version: v1.5.3
	Installer version: v1.5.3
	Operating system: #1 SMP PREEMPT_DYNAMIC Thu, 01 Feb 2024 10:30:35 +0000 6.7.3-arch1-1
	Catalyst license: none
It works as expected with bash.
Source Mode
Reading View
yes, the parsers between the views are different and the their support is different.
I am sure there are other cases like this. Hopefully one day we can use one parser for both views.
The reason I found this was actually trying to use the Execute Code with sh, and I suspect this issue in Obsidian is the root cause.
The original issue
Shell code works with bash but not sh · Issue #331 · twibiralobsidian/execute-code
