I also downgraded to 1.5.8
Happening for me on checkbox lists (for sure, haven’t tested elsewhere) and with gboard.
Same bug happens to me. Android, xiaomi’s phone. Japanese version. Using gboard with Kanji conversion support. This bug only happens on Obsidian, and after downgrading to 1.5.8, the bug never happened.
I really love obsidian so I hope this bug will be fixed shortly. This is great app. Thank you.
Same thing is happening to me when trying to make task boxes.
Trying to type; - Test
Results
Samsung key board: - estT
Gboard: - tseT
Turning off predictive test does not change anything.
Phone: Samsung Galaxy S23 ultra
Obsidian.1.5.11
Had started to happen to me yesterday. Disabling predictive text solved the problem for me
I think it is present on desktop too, to some degree. when I start start typing with an IME, the cursor ends up to the left of the first char, but the IME notices and bumps the cursor back to where it should be when you type another char? here is a lazy shaky cam lol https://youtu.be/4oaC1ia50V8
Having the same issue.
Samsung Galaxy Fold 4
Obsidian ver 1.5.11 (133)
Android 14, One UI 6.0
Samsung Keyboard 5.8.00.57
Turning predictive text off doesn’t fix it for me.
We are aware of this issue and will work on fix. There is specular problem that manifests mostly on desktop with IME input methods (here).
In the meantime, try to disable inline text prediction\spellchecking features or switch to a different virtual keyboard. We are sorry for the inconvenience!
This issue is happening for me on a Galaxy SW10+. I have uninstalled and reinstalled the app and cleared all data.
I can report the same issue on Samsung Keyboard. Additional info: For me, this happens after each spacebar in lines that have formatting applied, not only the first time after the formatting; example:
- bcda bcda bcda
Screen Recording of this behaviour is attached.
Screen_Recording_20240323_232554_Obsidian.zip (2.2 MB)
For me it happens on a Xiaomi Mi 9T running ArrowOS v11.0 Vanilla (no Gapps) with both AOSP and Openboard 1.4.5 keyboards, so definitely not limited to Samsungs.
I noticed it immediately after upgrading to v1.5.11. The “jumpy cursor” issue manifests itself in any special formatting (headers, italics…) but not in regular text. It is perfectly reproducible.
This is the most serious regression I have encountered so far in Obsidian mobile. I hope a fix will be quickly issued, as I haven’t been able to downgrade to the previous version using APKMirror version and this makes the app almost unusable.
+1 same issue here
Just bought obsidian
How to downgrade
Is there a plan to fix this bug and if yes what’s the ETA?
I have Samsung Tab S8+ with external keyboard. I have jumping curosr in all editing modes. The first letter after space was pressed will have curosr in front of the letter. If I move cursor or delete letter, then that word can be typed normally. Untill I again press space…
Thank you so much for linking to the official obsidian-releases, I didn’t know it existed! It allowed me to downgrade (after backing up my app data with NeoBackup). Now I can use Obsidian again ![]()
Facing the same issue on Samsung Galaxy S23. Android 14, One UI 6.0 and Obsidian 1.5.11
