Using the version 1.5.4.
On Windows, I press on the keyboard key Ctrl and move up or down the mouse scroll wheel, the zoom does not change.
Nothing happens.
Does not work either on the sandbox vault.
Zoom level should go up or down, when I press on Windows Ctrl and move up or down the mouse scroll wheel.
Does nothing.
Obsidian version: v1.5.4
Installer version: v1.5.3
Operating system: Windows 10 Enterprise 10.0.19045
Catalyst license: insider
Insider build toggle: on
Snippets enabled: 4
Plugins installed: 18
Plugins enabled: 16
1: Tag Wrangler v0.6.1
2: Natural Language Dates v0.6.2
3: Editor Syntax Highlight v0.1.3
4: Text Format v2.5.0
5: Omnivore v1.9.2
6: Image Converter v1.1.7
7: Templater v2.1.3
8: Dataview v0.5.64
9: Calendar v1.5.10
10: Mind Map v1.1.0
11: Settings Search v1.3.10
12: Homepage v3.7.0
13: Text Extractor v0.5.1
14: Omnisearch v1.21.1
15: Excalidraw v2.0.20
16: ToggleList v1.2.4
Same issue when using the sandbox vault.
I tried with Ctrl + + and Ctrl + -, and those shortcuts does work on all my vaults.
Maybe related to Ctrl+'mouse scroll wheel' doesn't zoom headings
