- Navigate to a note
- Switch to reader view
- Hit ctrl + a on keyboard
Should only select all text from the body of the note
It also appears to select the note title and part of the navigation breadcrumb at the top:
Obsidian version: v1.8.10
Installer version: v1.8.10
Catalyst license: none
Base theme: light
Plugins installed: 10
Plugins enabled: 10
1: Enhancing Export v1.10.9
2: Omnisearch v1.27.0
3: Recent Notes v1.3.1
4: Quick Explorer v0.2.14
5: Plugin Update Tracker v1.6.2
6: Pixel Perfect Image v1.0.11
7: Text Extractor v0.6.0
8: Editing Toolbar v3.1.16
9: Copy document as HTML v0.8.1
10: Local Backup v0.2.0
If you copy the text and paste it, it does just paste the note content as expected, so this appears to be a mostly superficial issue with the selection. However, you do end up with an empty line before the note content in the clipboard.
