As you can see in the pictures below, headings as Links are formatted differently as headings without links. Is there a possibility to overwrite the formatting of links with the formatting for Headings?
What theme and CSS snippets (if any) are you using? Knowing that will help in offering suggestions.
thanks for asking! I don’t use any snippets and use the minimal theme
Understood.
Where did you set the # Heading 1 (and other headings) color? In the Style Settings plugin? I ask because that maroon/red isn’t the default heading color for Minimal. Just checking what is happening and set currently.
