For all open vaults, enable cross-vault use of [[internal links]]. The internal links from one vault to another would be active and clickable as long as the “destination” vault is open. If that vault is closed, then the link would not be clickable. If the destination vault is closed perhaps Obsidian could display a tooltip message such as Vault <valult> is not available, or something like that.
I realize having a feature that would “break” if the right combination of vaults is not open is suboptimal, but the current work-arounds of having to set up obsidian:// URLs is also sub-optimal. The feature I’m suggesting utilizes Obsidian’s rapid linking feature, and I assume Obsidian can be aware of the open vaults in the environment. Correct me if I’m wrong.
Use obsidian:// file path or Advanced URI (plugin) links.
I didn’t find any, but I wouldn’t be surprised if others more knowledgable or adept than me have debated this feature at length.
Getting an Obsidian URL from A to paste in B is more steps than typing [[note name...]] and letting Obsidian do auto-find/complete.
Linking to #headings and ^blocks with URLs is even more complex.
If the destination note moves, the URL can break.
Obsidian tries to suggest strings within Obsidian URLs as “unlinked mentions” – this is partially avoidable, but not optimal.
Using the Advanced URI plugin with the UUID feature (i.e., the plugin finds the UUID in frontmatter) is a bit easier, and avoids the “note moved” issue, but still extra time spent flipping back and forth between vaults to grab and paste the URL.
For many reasons that I cannot change, I work between at least two vaults that are always open. “Internal linking” between them would be wonderful.
I don’t think that will ever be possible.
Obsidian exists within its vault. Anything outside is just files folders etc - even if they are sometimes vaults.
Only option would be nesting the vaults and doing the linking from the new top vault, which would be able to see all the files in both vaults. However, I suspect that, even if that were feasible for you, that your usage would cause problems.
Well, maybe. Maybe not. It’s software. The software can be aware of what’s in the open vaults.
And, perhaps, feasibility is a developer consideration. No harm at all in wishing.
I always feel “feature requests” in a user forum is a way for users to explain their wishes. Assessing what the developer can or cannot do is well beyond our pay grades, maybe. I would love to hear what licat or silver think.
Anyway, I mentioned above that I’m fully aware that if the vault at the other end of an internal link is closed, then the internal link would be broken. I accept that shortcoming.
I agree it is just software and wishes are welcome. There could be possible solutions. For #1, for example, it might be interesting to have a fuzzy-matching URL generator that can read all your open vaults, and make it easier to create a URL by searching.
For #3 I can’t see this being avoided. I certainly wouldn’t want anything I do in one vault to automatically change any aspect of another vault without my explicit consent. Especially if the vault was not open. And like you already pointed out, it could be inconsistent depending on whether it is open or not.
#4 Someone else flagged this as a feature request, and I personally think it could be considered a bug. I hope that gets fixed, or as an option to make it not suggest or change those links.
The symlink is a good idea. This is great because it utilizes the file system feature. It is maybe not as portable if you look on cross-plattform like Windows to Mac or iOS and Android.
Does anyone have experimented with this?
We (part time or full time) Windows users might get an interesting option with Windows 11 and next generation “Windows Subsystem Linux” (WSL)
I’d also like to be able to use internal links for notes stored in different vaults.
Just as I would like the ability to automatically update these links if the note’s title happens to be changed.
Perhaps a background process could be used for this purpose, one that would be responsible for monitoring changes made across different vaults? The developers know best.
Symlinks clutter your obsidian idnex and make Ctrl+O as well as ‘gardening orphan notes’ increasingly useless.
Here is an example for what I mean by ‘clutter your index’:
Step 1: Consider vault1 with note1.md with content
Hello This is some content inside note1. I want to have this content inside vault2. I also link to [[sensitive file name inside vault1]]. ```
Step 2: Symlink vault1/note1.md into vault2/ now inside vault2/randomnote you type [[sensitive]] and the autosuggestion will parse the index, find [[sensitive file name inside vault1]]. It will be suggested as an uncreated file.
Conclude: If you symlink and want clean separation of vaults, then you need to remember a) which files are an outgoing symlink and then b) which internal links are prohibited on notes that are symlinked to outside
I dont know if there is setting to make the obsidian index ignore outoging internal links on symlinked notes.
Or you can split note1 → note1-content.md and note1-outlinks.
For now the best solution seems to be to use symlinks and deal with 1), 2). Links just break and if you do ‘Ctrl+O’ and search for ‘README’ you may just have the readmes of stray symlinked projects in there that you didnt intend to sync into the index of vault2. One can deal with it.
EDIT:
A solution may involve creating a vault1/_leak/ folder, move files you want to leak there, put #public tags on your notes in vault1, then a simple linter checks that only #public files are inside vault1/_leak/ and outlinks only go to #publicfiles.
This is a ‘whitelist’ approach – conversely you could take a ‘blacklist’ approach, or add vault1/_leak/LEAK_CONFIG.json that allows you to switch from mode=whitelist to mode=blacklist and this .json can also track ‘receivers’ of the symlink as well as ‘symlinkpath’ if path/to/vault1/_leak/ not equal to LEAK_CONFIG.symlinkpath then the linter updates all symlinks pointing listed inLEAK_CONFIG.incoming_pointers.
That solves both problems .
