I want to be able to highlight text then select from an option to create a markdown link when I use the Control/Right-click hotkey.
Add option to create markdown link from selected text or clicked word as an option in the drop-down menu on Control-click/Right-click. This would be identical to Command/Windows key + K but can be done by mouse, which I like and is consistent with many other markdown applications and also with other non-markdown GUI text editors (though they generally donât use markdown link format).
Command/Windows key + K. I donât always want to use keyboard shortcuts and this Control/Right-click option is consistent and familiar with many other text editors.
I understand but I want exactly what was suggested, I can already use Command + K which is as good and doesnât require a community plugin.
This feature would be great particularly for new users from other applications (this precludes community plugins) because it is expected behaviour for many users coming from most other text editors. Also, I want it in the drop-down menu (like other text editors), I donât think there is a plugin that does this (is it even possible?).
Are there any restrictions on this as Iâve never seen an example of it. Also, would you happen to know of a community plug-in that implements this feature? I havenât found it if it exists.
Yes, I kind of want the opposite of this: obsidian://show-plugin?id=copy-url-in-preview. I might try contact the developer. Regardless, I still think this really ought to be a core and default feature.
