"Copy" for code blocks changes non breaking spaces to
For some code, when copying the code using Obsidian “Copy” button that appears on top right corner, spaces are copied as
The file for testing:
Untitled.md (44 Bytes)
Paste:
import pandas as pd
Paste when selecting by hand (either in reading, source or live preview):
import pandas as pd
All weys of copying should not replace spaces, whether non-breaking or breaking as code like  .
Copying should be consistent to make code being sharable and runnable!
Debug info
	Obsidian version: v1.7.4
	Installer version: v1.5.3
	Catalyst license: insider
	Plugins installed: 0
	Plugins enabled: 0
Related bug reports (probable)
I don’t understand this bug report. non breaking spaces are &nbsp.
What does it mean it changes non breaking spaces to &nbsp?
I mean that non-breaking spaces characters are replaced with “&nbsp” string when copying the code using the Copy button in Reading view.
I added the file into my original post for testing Untitled.md (44 Bytes)
Here’s a screen recording below to better illustrate.
20241022 - Obsidian code block copy nbsp
This is not wrong. The nbsp are present in Untitled.md.
The nbsp are placed as-is in the clipboard. In this case it’s notepad.exe that writes &nbsp
Yes they are, but not being replaced with some “&nbsp” string.
If you have a look at the screen recording, there’s definitely something inconsistent in the way this code block is handled.
It’s notepad.exe that does this replacing.
If you try vscode or notepad++ you will see the unicode char for nbsp.
I tried copying this code to VS code, slack and other software already, and they all behave the same
20241022 - Obsidian code block copy nbsp 2
ok, thanks you. I managed to reproduce.
Will be fixed 1.8
