Now that we have callouts, it’s becoming increasingly common to have blockquotes inside of callouts, or callouts within callouts. The toggle blockquote
command is insufficient as it’s designed for only one level of quoting.
Create separate commands for increase blockquote level
and decrease blockquote level
Either:
- Use vim shortcuts to do a visual block and then insert a
or delete a>
- Hold
alt
and draw a line where the>
chars are then insert a>
or delete a>
Increase/decrease quote level inside callout with tab talks about the TAB key.
