Two workarounds for macOS:
+1 for this… would also love to see Quick Note pop the app back up from minimized system tray status.
I have just downloaded Traymond and it does the job. (Shortcut: “Windows Key+Shift+Z”)
New to Obsidian and the lack of a global hotkey to show/hide the app would be a deal breaker for me. Fortunately this is easy to achieve on MacOS using Keyboard Maestro:
+1 Feature “Minimize Obsidian App to tray on close” is very useful. Evernote and other similar programms are able to do it.
Thanks for “alltray” tip!
Obsidian has a plugin called “Global Hotkeys” which is supposed to provide OS-level hotkeys to Obsidian actions…not sure if it works on Mac (haven’t checked yet). Might be another option for folks.
