What is the best way to take an existing vault and clone it to create another empty vault with all the settings/configuration/plugins of the original vault? I have set up a vault to learn Obsidian and, over time, have configured the vault with plugins and configuration settings to my liking. Now I would like to create another empty vault with all the same configuration settings including plugins. In other words, I am trying to achieve a vault template which I can use to create additional empty vaults.
Someone asked a similar thing earlier →
This is ripe for a plugin but I don’t have the coding skills…
I think you can copy the .obsidian folder to an empty vault, then use the settings menu to log out of your Obsidian account and Sync if applicable.
