CLI drops output when stdin is closed (eg: coding agents)
  • Open Obsidian like normal
  • /Applications/Obsidian.app/Contents/MacOS/Obsidian sync:deleted total # has output
  • /Applications/Obsidian.app/Contents/MacOS/Obsidian sync:deleted total </dev/null # no output
obsidian sync:deleted total </dev/null should print the same result as obsidian sync:deleted total, e.g.:
  612
Commands that do not read from stdin should not lose output just because stdin is closed or non-interactive.
The command exits with status 0 but prints nothing to stdout or stderr:
  # no output
  # exit code 0
Obsidian version: 1.12.7
Installer version: 1.12.7
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:33:25 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T6041 25.4.0
Catalyst license: none
Community theme: Minimal 8.1.6
Snippets enabled: 1
Plugins installed: 16
Plugins enabled: 16
1: Vimrc Support v0.10.2
2: Templater v2.20.5
3: Tasks v8.0.0
4: Tag Wrangler v0.6.4
5: Style Settings v1.0.9
6: Settings Search v1.3.10
7: Advanced Tables v0.23.2
8: Copy Block Link v1.0.4
9: Emoji Shortcodes v2.2.0
10: Global Hotkeys v0.1.2
11: Minimal Theme Settings v8.2.3
12: Paste URL into selection v1.11.4
13: QuickAdd v2.12.2
14: Relative Line Numbers v3.0.0
15: Excalidraw v2.23.5
16: Granola Sync v2.0.25
This affects coding agents like as pi, Codex, Claude Code, etc, where subprocess stdin is commonly non-TTY or already at EOF.
I searched for duplicates and did not find this exact issue - related but distinct threads:
This issue is different from requesting stdin-as-content support. The command above does not need stdin; closed/non-TTY stdin appears to cause the CLI connection to close before async command output is returned.
Note - I did use an agent to dig into this and prep the report, but tested quite a bit manually.
