CLI: command hangs when piping CLI output to the `head` command
  1. Open a terminal
  2. Run obsidian help | head -10
Yes.
The command prints 10 lines then exit.
The command prints 10 lines but doesn’t exit.
	Obsidian version: 1.12.3
	Installer version: 1.10.6
	Operating system: Darwin Kernel Version 25.2.0: Tue Nov 18 21:09:40 PST 2025; root:xnu-12377.61.12~1/RELEASE_ARM64_T6000 25.2.0
	Catalyst license: insider
	Insider build toggle: on
	Community theme: Cupertino 3.2.5
	Plugins installed: 46
	Plugins enabled: 20
		1: Style Settings v1.0.9
		2: Vault Statistics v0.1.3
		3: Paste URL into selection v1.11.4
		4: Outliner v4.10.0
		5: Quick Switcher++ v6.0.0
		6: QuickAdd v2.11.0
		7: Local Images Plus v0.16.4
		8: AttachFlow v0.4.5
		9: Paste image rename v1.6.1
		10: Advanced URI v1.46.1
		11: BRAT v2.0.2
		12: Dataview v0.5.68
		13: Image Captions v1.1.7
		14: Image Converter v1.4.1
		15: Kanban v2.0.51
		16: Linter v1.31.0
		17: File Cleaner Redux v1.13.4
		18: Collapsible Code Blocks v1.0.6
		19: Claudian v1.3.65
		20: Terminal v3.21.0
In kepano’s Obsidian CLI skill it says, “Run obsidian help to see all available commands.” Coding agents that read this will often run “obsidian help” and pipe its output to the head command to quickly verify it. Because the command hangs, the agents’ execution also stalls until it times out.
In the Troubleshooting guide, you are asked to download and reinstall obsidian, did you do it?
I didn’t reinstall before. After reinstalling, the problem persists.
Is obsidian already running?
because the cli works only if obsidian is already running.
Yes, it’s running.
If I remove the head part from the command, it works normally.
Thanks, this seems to be a mac specific problem
Hello,
I ran into the same problem. For what its worth, the LLM I’m using thinks the app isn’t handling SIGPIPE properly but I’m not really that makes sense if its a macOS only problem.
I did figure out though that while obsidian | head never exits, obsidian | cat | head works fine. This at least is able to be put in skill files to work around the issue for me.
I tested with version 1.12.5 and installer 1.11.7. Mainly posting to share the workaround I found.
Hello, you do need to try this with the new installer.
Please, go on discord channel #insider-desktop and after you have downloaded and reinstalled obsidian report back.
Thanks
Thanks WhiteNoise. I’ve added a post there. I updated to the 1.12.4 installer and am seeing the same behavior. I did notice something extra though.
obsidian version | head works fine
obsidian help | head does not.
obsidian help | cat | head works fine.
Seems like longer output causes the problem.
I am seeing the exact same issue (also on MacOS). Where does this need to be fixed? My understanding is that `obsidian` doesn’t handle the closed pipe correctly, when `head` received the lines it wants and exits.
@UserNIck did you figure out a working rule to add to the `SKILL.md` to work around the issue?
