Checkmark inverts/desynchronizes when changing editor more from view menu
  1. Set Initial State: Open a note in Editing View with Source Mode OFF (Live Preview enabled). Verify that in the View menu, Source Mode is unchecked.
  2. Switch View: Toggle the note to Reading View.
  3. The Trigger: While remaining in Reading View, go to the View menu and click Source Mode.
    Observation: The menu checkmark for Source Mode is now ON, but the note correctly remains in Reading View.
  4. The Desync: Toggle the note back to Editing View
Yes
The note should open in Source Mode (showing raw Markdown) because the menu checkmark is enabled.
The view state and the menu checkmark are inverted:
You’re in Live Preview but the checkmark indicates that you’re in Source Mode.
Obsidian version: 1.12.7
Installer version: 1.12.4
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:31:17 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T6020 25.4.0
Plugins installed: 4
Plugins enabled: 0
Toggling Source Mode while in Reading View seems to change the UI check mark but not update the actual program state.
thanks
  • Toggle Source Mode or Reading View from the note menu, or from command palette, or from keyboard shortcut
  • Open View menu on application menu and see that the checkmark is not set.
Yes. This testing was done in the Sandbox vault and other vaults.
On the application menu’s View menu, there should be a checkmark next to the Reading View or Source Mode (depending on which you enabled)
No checkmark set.
Obsidian version: v1.10.6
Installer version: v1.6.7
Operating system: Darwin Kernel Version 24.6.0: Wed Oct 15 21:08:19 PDT 2025; root:xnu-11417.140.69.703.14~1/RELEASE_ARM64_T8103 24.6.0
Catalyst license: insider
Additional Information
  • This puts the application menu, View menu and the note’s menu out of sync.
  • If this action is done only from the View menu, both View menu and note menus remain in sync
+1 On this
Installer version: 1.12.7
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:33:50 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T6050 25.4.0
Language: en-GB
Plugins installed: 7
Plugins enabled: 7
1: Templater v2.19.0
2: QuickAdd v2.12.0
3: Linter v1.31.2
4: Readwise Official v3.0.2
5: BRAT v2.0.4
6: Base Board v1.6.0
7: Self-hosted LiveSync v0.25.57
