Canvas is not rendered correctly when embedded in a note
TL; DR: Check out the video: iCloud Drive - Apple iCloud
  1. Create a Note. Name the note something like Example Note.md
  2. Create a Canvas, and put a few cards in it. Name the canvas something, eg Sample Canvas.canvas
  3. Embed the canvas in the Example Note.md note using the markdown as
![[Sample Canvas.canvas]]
The Canvas
The Note (in source mode so that we can see the text embedding)
It is reproducible in the Sandbox vault, and also reproducible in a new empty vault that I created. The problem persists after restarting the computer. I also couldn’t find an open issue with similar problems.
I expect that the canvas will be correctly rendered embedded in the note. When I say “correctly”, I mean that the embedded note should show the text inside the cards.
It is embedded incorrectly. Only the outline is shown - the content in the cards is lost.
	Obsidian version: v1.3.7
	Installer version: v1.3.4
	Operating system: Darwin Kernel Version 23.0.0: Tue Aug  1 03:25:23 PDT 2023; root:xnu-10002.0.242.0.6~31/RELEASE_X86_64 23.0.0
	Catalyst license: none
	Legacy editor: off
Mismatch between installer and Obsidian versions
I also updated the Installer version to v1.3.7 after noticing the difference here, but the same behavior persists.
  1. I am currently on a beta version of MacOS Sonoma. That might be the reason behind the issue. In that case, even though this is not a real issue, you folks might want to fix that to prepare for the release.
I will appreciate any suggestions and/or help regarding this. :smiling_face:
I think this has been reported at least once or twice already.
This is the intended behaviour, I seem to remember they said. You need to click into it.
If that is the case, I apologize for not searching for a duplicate enough. Can you please share a link to one such Bug Report so that I can merge this one in there, and look to see alternatives suggested by others, if any?
I’m afraid I cannot. But a moderator prolly will.
Cheers
This how it currently works, intentionally. There’s an open FR to do more.
Hi @WhiteNoise, thank you for responding. Is this the FR?
