Canvas does not update relocation of project folder - following the PARA-method
  1. Open a new canvas
  2. place files there which nest in a project folder
  3. move the project folder to for example ‘Recources’ (following the PARA method)
  4. now you get error messages
It shoud update the links to the moved folder
Error message
Obsidian version: v1.8.9
Installer version: v1.8.9
Operating system: #202412060638~1743109366~22.04~1fce33b SMP PREEMPT_DYNAMIC Thu M 6.12.10-76061203-generic
Language: de
Catalyst license: none
Plugins installed: 42
Plugins enabled: 16
1: Excalidraw v2.8.3
2: Dataview v0.5.67
3: Advanced Tables v0.22.1
4: Calendar v1.5.10
5: Tasks v7.14.0
6: Outliner v4.8.1
7: Omnisearch v1.26.0
8: Recent Files v1.7.4
9: Natural Language Dates v0.6.2
10: Emoji Toolbar v0.4.1
11: ExcaliBrain v0.2.15
12: Dictionary v2.22.0
13: Image Converter v1.3.4
14: Remember cursor position v1.0.9
15: Better Export PDF v1.10.2
16: Regex Find/Replace v1.2.0
It seemed to me similar to the problem which was reported 2022 ( Links from Canvas’ Cards are not updated when a link is changed and they do not appear in the Canvas’ outgoing links
I don’t see any issues on my end in a quick test moving a folder.
Obsidian_gfsF9RkfKK
I’d try again with Restricted mode on if you haven’t yet.
Hello Ariehen,
I also restarted my laptop now it works in sandbox and in my main vault.
Thank you for your screen record!
