Moved vault from iCloud to Home folder. Opened new vault pointed at new location and synched. Turned plugins back on. Plugins and settings remained.
Once everything is on, Calendar pane not accessible.
Should see Calendar in pane.
Calendar pane isn’t visible.
Only calendar commabd in pallette is “Calendar: Show active note”
View calendar isn’t visible from any of the three dot menus.
I updated the plugins, quote and restarted a couple of times, toggled everything on and off a couple of times…
I even tried closing and opening panes (per the similar bug in the forum)
