Add a syntax like
paragraph 0.
paragraph 1.
::: ^block_id
to support more flexible block reference.
Maybe it will also influence a block style solution like annotation syntax:
::: .danger
DONT divide any number with ZERO!
::: ^DivZeroError
Or use two same block id to sign up a block:
^abc
Paragraph.
ABC
^abc
The existing block reference syntax looks like
Paragraph. ^block1
Paragraph 2
^block2
But I want it support two or more paragraphs, such as a formula and its explain
E^2 = m^2c^4 + c^2 p^2
+ $E$ energy
+ $m$ mess
+ $p$ momentum
+ $c$ speed of light
::: ^EinsteinFormula
I have using quote block to make them into one block element:
> + $E$ energy
> + $m$ mess
> + $p$ momentum
^EinsteinFormula
But it use a dirty semantic.
This syntax inspired by pandoc’s markdown.
- Custom length of Parent and Child in list may be solved with the same method.
