When you click on a note in the File Explorer, it opens that note in the most recently viewed pane. I’d like to be able to open an MOC note in the sidebar and open links in it the same way: have them open in the most recently used pane. Right now there are only two options: you can either open a link in a new pane, or open in in the same sidebar tab as the MOC, replacing it.
Not having a way of using notes this way severely limits the usefulness of MOCs, as navigating using them is not as convenient as using the File Explorer.
Add an action that allows you to open a link open in a sidebar note in the most recently viewed pane. Ideally, this would work contextually, so that I could replace the default click with it, but it would also be ok as a workaround if this required a special keyboard shortcut.
