Was browsing the forum when I found this post, about applying a template to multiple files. If you think about it, a template is just some combination of properties, which is just some markdown. So, made a quick bash script to help anyone doing a similar reorg of their notes folder!
#!/bin/bash
# Specify the directory containing markdown files.
# Replace '/path/to/markdown/files' with the actual path to your markdown files.
DIRECTORY='/path/to/markdown/files'
# Iterate over every markdown file in the specified directory.
for file in "$DIRECTORY"/*.md; do
# Check if the file is a regular file.
if [ -f "$file" ]; then
# Extract the date from the filename (relevant to me since my file names were the date, which I wanted to put in the created property)
filename=$(basename -- "$file")
file_date="${filename%.md}"
# Temporarily store the existing content of the file.
temp_file=$(mktemp)
cat "$file" > "$temp_file"
# Write the YAML front matter to the file.
echo "---" > "$file"
echo "created: $file_date" >> "$file"
echo "tags:" >> "$file"
echo " - note" >> "$file"
echo " - journal" >> "$file"
echo "---" >> "$file"
# Append the original content back to the file.
cat "$temp_file" >> "$file"
# Remove the temporary file.
rm "$temp_file"
fi
done
echo "YAML front matter has been added to all markdown files in $DIRECTORY."
