ironhak
December 26, 2022, 5:53pm
1
Hello everyone, I’m tryong to have a decent result with banner plugin and I also tried using the snippet fix from github but result is not good, look:
And with css looks like:
This is the snippet:
.banner-bug .inline-title {
margin-top: calc(var(--banner-height) - .5rem);
margin-bottom: calc(var(--banner-height) 500rem);
margin-left: 0rem;
position: relative;
Is someone able to fix this? Thnk’s.
xoSidon
December 26, 2022, 6:44pm
2
What precisely are you trying to accomplish?
ironhak
December 26, 2022, 7:25pm
3
Hello, I would just like to remove that huge empty space between note inline title and first header
xoSidon
December 26, 2022, 10:46pm
5
Explanation
So, I went ahead and searched for the original snippet in the Github issues and found it here .
margin-top: calc(var(--banner-height) - 1.5rem);
margin-left: 6rem;
position: absolute;
Modifications
In your snippet you added a bottom margin of 500rem and changed the top margin to be .5rem less then the margin top. In addition, you changed the position to relative instead of absolute
The margin sizes are cosmetic preferences; however, the left margin should be set to 6rem if a banner icon is set . The position should be relative , if you would like to enable a theme that offsets the position of the inline title
In addition, the change in the .inline-title position causes the div.obsidian-banner-spacer to be offset resulting in the large space that you see
Solution
Therefore, your CSS snippet is structurally sound. However, I recommend adding;
.banner-icon-bug .inline-title {
margin-left: 6rem;
position: relative
As a result, you’ll be able to set the cssclass to banner-bug or banner-icon-bug depending on whether you have a banner icon or not
Finally add this line,
div.obsidian-banner-spacer {
position: absolute;
ironhak
December 26, 2022, 11:51pm
7
Hello! thanks for your time but the problem persist:
Have you tried to replicate the problem?
xoSidon
December 27, 2022, 1:12am
8
The final CSS snippet will be,
margin-left: 0rem;
position: relative;
margin-left: 6rem;
position: relative
position: absolute;
banner-bug.css (311 Bytes)
xoSidon
December 27, 2022, 1:23am
9
My apologies, in my last “final CSS snippet” reply. I neglected to type out the most important line ,
position: absolute;
Also, yes, I did replicate the bug
Before
After
ironhak
December 27, 2022, 7:30am
11
I don’t understand, am I doing something wrong?
I just downloaded your snippet with no modifications, I also tried to disable all my other snippets. Thank’s
ironhak
December 27, 2022, 7:36am
12
Maybe I found a solution, I added a line to your script:
margin-bottom: calc(var(--banner-height) - 37rem); //ADDED LINE
margin-left: 0rem;
position: relative;
margin-left: 6rem;
position: relative
position: absolute;
Which produces the desired result:
Since I’m no coder I would like to know if this is a suitable solution or not. Thank you again
