Backslash not shown in inline code blocks
In any note, type an inline code block with a backslash character (e.g. \something, or even just \).
Yes I did :slight_smile:
I would expect to see the backslash character in the inline code block, with no processing, independently of the cursor position.
  • The code block is rendered correctly if the cursor is inside the block itself, or adjacent to one of the backticks.
  • An additional blank space is added after the backslash character if the cursor is on the same line, but not adjacent to the code block.
  • The backslash is not displayed at all if the cursor is on a different line.
	Obsidian version: v1.6.1
	Installer version: v1.5.12
	Operating system: Darwin Kernel Version 23.5.0: Wed May  1 20:12:58 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T6000 23.5.0
	Catalyst license: vip
	Insider build toggle: on
Here is a GIF showing the issue
GIF
Here’s mine:
I don’t see the behavior you describe, in either inline code or code blocks.
Operating system: ios 17.5.1 (Apple iPhone14,5)
Obsidian version: 1.5.12 (134)
API version: v1.5.12
Catalyst license: none
Snippets enabled: 41
Plugins installed: 55
Plugins enabled: 15
1: Periodic Notes v0.0.17
2: Folder Note Core v1.3.5
3: Shortcut Launcher v1.1.0
4: Regex Find/Replace v1.2.0
5: Reveal Active File Button v2.0.3
6: Smart Random Note v0.2.1
7: Smart Typography v1.0.18
8: Sort & Permute lines v0.7.0
9: Calendar v1.5.10
10: Stille v1.3.4
11: Word Sprint v0.2.5
12: Custom File Explorer sorting v2.1.8
13: Advanced Merger v1.5.0
14: CSS Editor v1.1.0
15: Excalidraw v2.2.3
[omitted]
Obsidian version: v1.5.12
Installer version: v1.5.8
Operating system: Darwin Kernel Version 23.5.0: Wed May 1 20:16:51 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T8103 23.5.0
Snippets enabled: 32
Plugins installed: 54
Plugins enabled: 17
7: Quiet Outline v0.3.26
9: Natural Language Dates v0.6.2
10: Word Sprint v0.2.5
11: Calendar v1.5.10
12: Tag Wrangler v0.6.1
13: Stille v1.3.4
14: Garble Text v1.2.0
15: Text expand v0.11.4
16: Smart Typography v1.0.18
17: Custom File Explorer sorting v2.1.8
[omitted]
…Those “snippets enabled” numbers are weirdly wrong — I have 24 out of 33 enabled, not 41 or 32. (There are another 5 in a subfolder.)
Inline codeblock has this problem.
`test \ing`
Could you please paste the output of the “Show debug info” command?
I can reproduce this with sandbox vault.
Operating system: Windows 10 Home 10.0.19045
Catalyst license: supporter
This seems to be a regression in 1.6.1 vs 1.5.x. I don’t think 1.6.0 had this problem either.
thanks
will be fixed v1.6.4. No ETAs.
I have the same issue, whether the backslash is in inline or not. When I tried to type \w: it removes the backslash. And when I type \w: without the inline code markers it still removess the backslash. This happens in sandbox mode as well. To reproduce the issue, the backslash must be the first character of a code block or sentence. For backslashes at the beginning of a sentence or line, it can be remedied by typing a second backslash or escape character. However, for code, this does not work.
Obsidian version: v1.6.3
Operating system: Windows 10 Pro 10.0.22631
Community theme: Minimal v7.5.4
Plugins installed: 17
Plugins enabled: 14
1: Importer v1.6.1
2: Advanced Tables v0.21.0
3: Paste URL into selection v1.7.0
4: Minimal Theme Settings v7.5.0
5: Style Settings v1.0.8
6: BRAT v1.0.1
7: Breadcrumbs v4.2.35-beta
8: Colored Tags v5.0.0
9: Tag Summary v2.1.5
10: Dataview v0.5.66
11: Open vault in VSCode v1.2.2
12: Buttons v0.5.1
13: Outliner v4.8.1
14: Highlightr v1.2.2
I hope this fix will be released very soon. This is a total showstopper for me. Rolling back versions now.
