You many like to look at this site link, it is build around Mathjax and has very good interactive equation referencing.
Hopefully something can be salvaged.
This command doesnât render properly for me. Is there are updated way to do this? I am using v1.3.5. Here is my result
Please, read the rest of the thread.
Tldr. It doesnât work.
Hi everyone, Iâve recently made a plugin for automatic equation numbering (as well as other powerful features)!!
Try LaTeX-like Theorem & Equation Referencer (previously called âMath Boosterâ).
When an equation is referenced by an internal link ([[note#^block-id]]), the equation will be dynamically numbered, and the link is displayed with the corresponding equation number like â(1)â.
Here are some screenshots: Equations
For questions & discussions, please use this thread on the showcase category.
Thanks!
Nice! I will definitely give it a try.
Please, open a thread in share and showcase and continue the discussion about the plugin there. Thanks!
Sorry, Iâve added the link to the showcase thread that I made before, thank you for pointing it out!
You can check how I do it in the plugin I wrote here.
Navigate to the equation writing part, wherein I use QuickAdd. You would have to make it show the title of the equation note-block, which is a small modification
