Auto-capitalization in bulleted lists not working on Android
In any normal note start a bulleted list with "- ".
When finished with line tap enter to go to new bullet.
Capital letters appear in keyboard for a fraction of a second and then change to lower case.
Yes. Created a new vault with no community plugins or anything. Big still occurs.
Each time I enter a new line, the first letter should auto-capitalize.
Letters are capitalized for a fraction of a second then turn lower-case
Operating system: android 14 (samsung SM-F721U)
Obsidian version: 1.8.9 (195)
API version: v1.8.9
Catalyst license: none
Plugins installed: 7
Plugins enabled: 7
1: Dataview v0.5.67
2: Advanced Tables v0.22.1
3: Calendar v1.5.10
4: Omnisearch v1.26.1
5: Recent Files v1.7.4
6: Periodic Notes v0.0.17
7: Templater v2.9.3
Bug is happening on Gboard and Samsung keyboards
I have an unlisted YouTube short but it won’t let me submit with any links. But I think it’s pretty straightforward
I do not see this.
We have this big other problem though Enter in Lists on Android/Gboard doesn't make next bullet point, checkbox, etc (due to autosuggest, autocorrect)
My bad for the long delay, I have a video of the behavior I’m seeing in an unlisted YouTube short. As I’m not able to post links, how would you like me to get it to you?
Got the same bug here in a brand new, clean vault for source mode and live preview.
Also occurs if you type to create a dotpoint or use the keyboard command.
Gboard shows caps for a split second, Swiftkey always shows lower case.
Same deal with checkboxes.
Screen recording link of this using Swiftkey on a brand new, clean vault: streamable(.)com/g9rabi
Remove brackets from link to use it.
These are my details:
  • Android 11 (TCL 20 Pro)
  • Obsidian 1.89
  • Login status: logged in
  • Language: en
  • Catalyst license: none
  • Base theme: dark
I have the same issue. It occurs with and without community plugins and themes enabled.
Operating system: android 16 (Google Pixel 9 Pro Fold)
Obsidian version: 1.8.10 (197)
API version: v1.8.10
Live preview: off
Community theme: Minimal v8.0.1
Plugins installed: 9
Plugins enabled: 9
1: Importer v1.6.21
2: Minimal Theme Settings v8.1.1
3: Hider v1.5.1
4: Style Settings v1.0.9
5: Custom Font Loader v1.6.0
6: Editing Toolbar v3.1.16
7: Dataview v0.5.68
8: Kanban v2.0.51
9: Clear Unused Images v1.1.1
You can write a link to the view by putting it withing a `codeblock`
Thanks, this is the video of the behavior. Still happening even in fresh vault with no plugins.
https://youtu.be/slS5sHnEJGY
