Appimage: obsidian0.9.17~obsidian0.13.33 is running normally,But it can’t run after version 0.14, hope to fix the bug of version 0.14
./obsidian
./obsidian: /usr/lib/aarch64-linux-gnu/libxkbcommon.so.0: version `V_1.0.0’ not found (required by ./obsidian)
(Obsidian-0.14.6-arm64.AppImage does not work.)
- Operating system: OS: kylin v10
This is an upstream problem. It will be fixed eventually. Use an old installer version in the meantime.
Will be fixed in 0.14.15+, you will need to download and reinstall obsidian from the website when it’s released.
system
Closed
4
