Hello everyone,
I would like to Obsidian to always open the same vault when i open it on my phone.
I found solutions on this topic using it on pc with a uri.
But couldn’t find anything for mobile.
Thanks in advance
Hello everyone,
Thanks in advance
Yeah, you can do it with a Siri Shortcut using the Obsidian URL scheme. Make sure you encode the URL (the vault name) if it contains spaces.
Thank you, but i have an Android phone.
Should have added that
Not sure the state of launcher apps on Android at the moment, but a URI link in a notepad app (or whatever) to a certain vault or inbox note in a certain vault should work. Give it a try:
Unfortunately this is only talking about Windows, Mac and Linux.
No Android
Obsidian URIs work (mostly) on iOS without using Shortcuts. I have a URI in Apple Notes that opens an Obsidian vault. Don’t see why it wouldn’t work on Android. Have you tried it?
No, i didn’t. I’m not familar with this uri stuff.
How does it work on apple?
You make a link and click it.
If your vault is “Snens”:
obsidian://open?vault=Snens
If your vault is named “Snens ideas”:
obsidian://open?vault=Snens%20ideas
Snens or Snens ideas. If the vault is already open, it will focus on the window.If you have Android and Tasker is still functional (I haven’t used it in a long time), you can make a shortcut (or equivalent) with Tasker or some similar app and use it.
I know about the links inside obsidian, i just need a vault that opens quickly where i can write down a spontanous thought.
I know i don’t make it easy for any of you, but again i don’t know anything about tasker or how to use a uri.
There are at least 2-3 forum posts with the same desire in mind. At least one of those was that of an Android user.
I’m going to tap out here, but I’ll just say: if you aren’t willing to put in the work on your end, I don’t think there’s much more we can do for you.
I did not remember what post it was (it was a lady asking, what I remember), but searching for quick capture yielded:
https://forum.obsidian.md/t/quick-capture-for-android/37573/2
and:
I am sure there are much more.
I found a solution using the first post u send and this post (all the way down).
Thanks everyone ![]()
