Looking to preview a variety of file types in links from Obsidian, as opposed to opening the docs for editing.
In Windows, QuickLook and several similar apps attach themselves to System Explorer and display a low-overhead doc preview when a doc is selected in Explorer and the user presses the space bar. It’s much nicer than Explorer’s own Preview Pane.
So I’d like to alt-click on file:/// links or use the context menu to select the described doc in System Explorer as a simplified way to display the doc in a floating file preview pane.
Related feature requests
Other folks have expressed an interest in multi-format previews inline via insert/embed. A floating preview pane would be about as useful, and would be easier to achieve in Windows by this mechanism.
Insert/Embed other file formats like .xlsx and .docx (but not limited to) in addition to pdf and images
Thanks for considering! - Jerome
