When creating a new heading, it’s challenging to figure out the correct heading level (H1 through H6) to stay under the current parent heading - I manually go to the previous heading, make a note of the number of "#"s and type/copy-paste them.
If I could use Option (macOS) or some way to enter a heading at the same level as the previous heading, that would simplify this problem.
I would love having in core all options from Heading Shifter - Obsidian Plugin (which has a lot of issues in scorecard) but at least the following would be incredibly helpful.
Command
Description
Insert Heading at current level
Change current line headings to current level
Insert Heading at one level deeper
Change current line headings to current level + 1
Insert Heading at one level higher
Change current line headings to current level - 1
“Insert Heading at current level” as a core implementation is needed for several users.
