Similar functionality exists in wiki.vim.
+1
This would be a useful feature.
+1 for this feature
+1 for this feature as core.
The folder-note add-on is not a bad workaround but doesn’t offer anywhere near the same functionality.
I would suggest more: Make it so that folders can double as notes. Ie. Contain text, be linked to, yet still act as folders. This is an outstanding feature of Notion. Although not strictly in the spirit of zettelkasten, it affords incredible flexibility for sorting and filing notes, so powerful.
I think it is important to remember that the intent of Obsidian is that you have your notes locally and they are in a form that is hoped to be future proof. What we have is a file system hierarchy of plain text notes. Obsidian provides a way to view/edit and add functionality/meaning to the plain text notes.
I think linking to folders Ia a common file system paradigm and I find it missing and should be supported. And the File Explorer should allow me to select a folder when I do a ctl-O. I thinl that the folder notes plugin is the right solution for doing more. In the file system you can create a note with the same name as a folder. The folder notes plugin adds a convention and GUI paradigm as to how to treat these notes.
Lets separate presentation from the storage model.
+1
I need it
+1
Came here looking for this.
A link to a folder should expose the folder in the Explorer.
A year later, I’d still like to see this happen. A link to a folder could have a slightly different syntax, similar to
Relevant to feature request:
“links as first class citizens”, this will be really helpful
+1 from me. This’d open up all kinds of potential organizational methods that are currently very clunky to implement.
EDIT:
I imagine the ideal scenario would have two options, just like creating backlinks:
Clicking [[someFolderPath]] The command Files: Reveal current file in navigation does exactly what I would picture this function doing: jumping to the folder’s location & strobing a highlight color.
The alternative, ![[someFolderPath]] could write out a list of all the files and folders in the given folder. Perhaps, if we wanted to get really fancy it could have a few pipe options such as ![[someFolderPath|files]] to display only files, ![[someFolderPath|folders]] to display only the folders, or without a pipe option, which would display both files & folders.
