I would like to switch from Joplin to Obsidian to try Obsidian but I have a problem with SOME images attached in notes.
Joplin stores all note images in a folder called “_resources”.
I have imported the .md notes and the _resources directory (which contains all the images) into my vault.
When I open a note some images from that directory are shown but others show me the message: “the attachment is not created yet”
I already know where the problem is, the problem is that for example, the images that are not seen contain spaces.
When entering Joplin’s note to Obsidian, it shows me the images in the md file like this:
.png)
On the other hand, if I add a “%20” in the spaces, then the image is shown, leaving the line like this:
EDIT: One of those solutions is for Evernote and the other is a shell script, which is technically a solution but also a hassle.
Does anything here work?
One of the original solutions that the poster tried sounds like it worked but left out the front matter — if you don’t have front matter, then maybe it’s good enough.
