+1, settings for local or global graph, like profil setup, or another way, or trigger if a property exist, …
Hi! This looks like a very useful solution, so thanks for the lead!
I installed the plugin and now I am struggling with how to set the presets
as I follow the readme section. Particularly, I am stuck with understanding what the “preset view
” is, and what to exactly edit once I get there… Have googled it but couldn’t find an answer. Would be very grateful if you could kindly guide me into this super quickly.
It’s worth mentioning that, even if I think that I have (manually) installed the plugin successfully, I do not see it in the list of community plugin settings; perhaps because it’s still in beta.
Thank you very much!
This would be excellent if possible or at least global settings for local graphs that does not reset.
There is a plugin the syncs all the settings from the global graph to the local graph. It has to be synced every time a local graph is opened though.
obsidian://show-plugin?id=sync-graph-settings
