Adding shortcuts to the right click context menu
The current method of navigating the right click menu with the keyboard is tedious.
I suggest that each button in the context menu is assigned a key to activate it.
For example, r could be used to rename the link below the cursor
In my example use case, it would require pressing the up arrow key 6 times to do an action that could take just one.
Related Feature Request
As someone who tries to do everything by keyboard, I agree that this would be a very handy feature.
On macOS at least, you can type a few letters of the menu item text to get closer to your target, as this is a native menu
Sadly its not available on all systems.
+1 for this!
Are you on Windows? Have you tried turning on native menus in Obsidian under the Appearance tab?
With a native menu you can indeed navigate through the option by pressing letter keys like @obsequious suggests.
Thank you for the advice, I’ll look into when I get back to my computer
