I’d like to add a counterpoint to the counterpoint. Example 571 of the CommonMark spec distinguishes between image description and title.
is rendered to HTML as
<p><img src="/url" alt="foo" title="title" /></p>
According to the HTML specs the <alt>-tag “must be an appropriate replacement for the image”. AFAIK this tag is more about accessibility and fallback than about a caption.
The specs continue later: “If a caption is to be included, then either the title attribute can be used, or the figure and figcaption elements can be used. In the latter case, the image would in fact be a phrase or paragraph with an alternative graphical representation, and would thus require alternative text.”
<ALT> is not a good place for captions.
But if Obsidian supported <TITLE> for captions, it would be compliant with CommonMark and HTML specs.
Yes, of course. This is the Markdown of the examples shown above:
Voluptate et repudiandae nulla laudantium quia et et vitae voluptas aliquam ab. Asperiores aliquid nisi non quidem autem quis iure autem commodi esse sit voluptates libero nostrum autem.
> [!figure] ![[35.jpg]]
> *Figure 7*: Occaecati rerum error quis assumenda **perferendis** sequi eos in id.
Debitis voluptatem accusantium dolorem cum voluptatem voluptate. Hic maiores earum eligendi eveniet sed veniam molestias perferendis animi doloribus amet qui earum.
> [!figure-right] ![[35.jpg]]
> *Figure 8*: Occaecati rerum error quis assumenda **perferendis** sequi eos in id.
Sequi quidem rem dolor rerum repellendus libero neque iure sequi et. Debitis est eius nobis nobis eum facere. Nesciunt commodi aut aliquam quidem repellendus asperiores sapiente molestias dolores dignissimos eos libero iusto.
Aut quo nisi est voluptas dolorem dolor sint ut iure. Voluptas temporibus commodi culpa dolorem possimus incidunt. Voluptas sed sint delectus voluptates et libero eos sed ducimus laborum id est qui quidem. Qui dolorum veritatis doloribus aliquam autem cum ipsam. Aut eum et quidem autem ea accusamus et repellendus tempora. Assumenda rem minus commodi nostrum et exercitationem facilis voluptas modi debitis ratione sed.
> [!figure-left] ![[35.jpg]]
> *Figure 9*: Occaecati rerum error quis assumenda **perferendis** sequi eos in id.
Incidunt voluptas ut architecto aut dolorem dolorem ipsum quisquam nemo laudantium id est molestias laboriosam. Temporibus commodi quam repellat doloremque est est reiciendis in quibusdam non unde.
Thank you for adding this. Callouts for captions is a great solution for the current project I’m working on. For anyone in future, you can also add the following to get the images centered.
.callout[data-callout^="figure"] {
max-width: 40%;
margin-left: auto !important;
margin-right: auto !important;
Hello. Thanks for this. The caption is showing to the right of my image, do you know how I can have it show beneath the image? Have tried various edits to the css but hasn’t worked.
Here’s a quick Templater template which will turn any selected image into a table in that format, and position the cursor so you can immediately start typing a caption:
// Get the image Markdown
const text = tp.file.selection()
// Insert the table
tR += `
| ${text.trim()} |
// Move cursor into position to edit the caption
setTimeout(() => {
const cursor = app.workspace.activeEditor.editor.getCursor()
app.workspace.activeEditor.editor.setCursor(cursor.line - 1, 2)
}, 150)
It’s great that people have found workarounds and what have you, but I don’t want to get into the weeds with plugins or custom CSS — that’s too much like working on the system rather than in it for me. I just want it to work natively within Obsidian. Surely that must be possible?
