I use Obsidian Mobile on iPad with mouse and keyboard.
This BR is simple to explain: its NOT possible to copy/duplicate a group/node on Obsidian Mobile using these two approaches:
โ Keyboard Hotkey Mod+CMod+V
โ Commands CopyPaste
Using the Command Palette you could see that inside a Canvas File we dont have the CopyPaste commands.
Obsidian 1.4.2 iPadOS 16.3
This BR was generated testing Obsidian Mobile in a Vanilla Vault without any plugin installed.
Steps to Reproduce
1- Open a Canvas File
2- Selecet a Node
3- Try to hit the CopyPaste hotkeys
or
3- Open Command Palette and search for the CopyPaste command
Will this be fixed anytime soon?
Not sure if this is an OS limititation or an easily implementable feature, but itโs def a very important feature to properly use it on Ipad
I would even consider this a bug rather than a feature
I hope youโll add this feature. My workflow - I have an legend of nodes with selected colors and text templates and I copy it to the right places while โdrawingโ or redesigning the canvas
This feature would be really useful to me as well! I primarily use desktop for my canvas work and I feel like Iโm missing a limb when I work on my iPhone without copy and paste. Adding it would be greatly appreciated when you have the chance!
