I am using a canvas to create some kind of dashboard with multiple cards. So it is nice to have a fixed view on canvas. (By “view” I mean not part of the interface but “camera” position on canvas)
I use read-only mode, but sometimes I scroll outside of a selected card, or accidentally drag-select near the edge, which moves the view.
Add an option to lock view, which disables moving and zooming the view on canvas. Toggle can be added next to “Read-only” toggle.
Hello!
I tried to make a plugin for that, but as the function for dragging and zooming are not in the main API, copy the original function is difficult.
I tried to save them into object but some times after use these function become overwritten so it disable completely the function in non-readonly mode.
If someone have an idea on how to make that, I will be happy to know.
Because of the absence of view lock, I barely use canvas :<.
UPDATE
I think I have something workable. Very experimental: GitHub - Lisandra-dev/obsidian-better-canvas-lock
