While it is possible to add an entire note using the “Drag to add note from vault” command, this doesn’t allow the adding of headings and blocks as individual editable canvas elements.
It would be extremely helpful to be able to use the “Drag to add note from vault” command to add headings and blocks as individual editable canvas elements.
Add sections / blocks to Canvas view - This request was marked solved which is why I’ve created this new request.
Thanks!
