Currently, if you select a link in the outgoing-links pane (core plugin), you only have the option to open the link in the current editor (by CLICK) or in the new window (by CTRL-CLICK).
I’d like to be able to work with outgoing links in the same way as with the links in the text editor itself, especially to open the file in a default app or locate it in the system explorer. What I mean is that right-clicking on the link in the outgoing-links pane should bring up the context menu with all standard options available for links (Open in new window, Rename, Copy obsidian url, etc).
I find the outgoing-links pane very important, as it’s the best way to see all attachments and media related to the note in question.
Add context menu for links in outgoing-links pane.
First you must find the respective link to the attachment in the text editor itself and then you can use the context menu there, but it´s not so convenient and fast.
Many thanks for the great product.
