Active Links within Code Blocks
If a plugin could allow links to work from within comments in code blocks, it would help so much for marking up briefly with links to further description elsewhere. It wouldn’t have to only work within comments because perhaps the language isn’t supported for syntax highlighting.
related: Collapsible code block comments
workaround: You can currently use the folding within code blocks to hide away your longer comments as opposed to linking to them elsewhere.
Thanks!
You can use Links in my plugin. You could even use Annotations if you prefer that method:
