Ability to use canvas as daily note
It would be great to be able to use a canvas as a daily note.
When the template file is a canvas, the newly-created daily note file should be a canvas as well, with the date as the title.
It would also be nice if the settings for the daily note core plugin simply provided the option of choosing between creating a markdown file, creating a canvas, or using a custom template file, to make things just a tad smoother. But this isn’t necessary for the core functionality.
This response to a plugin idea post features a workaround that relies on having a canvas with filename {{date}}.canvas embedded in the template note. However, this results in two files (the daily note itself and the resulting canvas), which is cluttered, and requires an extra click.
I couldn’t find any feature requests for this, but for the sake of backlinks, I did find a plugin idea post and a help question.
