Hi Everyone,
It would be nice if there was some sort of guide or tutorial on how to create an obsidian plug-in. I know how to do Machine Learning code but would need guidance on how to plug it into Obisidian.
Any help would be appreciated.
Thank you!
argentum wrote an FAQ guide here. Near the bottom of that post, you’ll find a link to the API and a link to a sample plugin.
How to install plugins?
Installation instructions for 0.9.8+
If the author has registered their plugins with the Obsidian devs, you can find the plugins in Settings > Third-party plugin > Community plugins.
Note that the manual installation for 0.9.7 continues to work, so your plugins will still be usable even if the author hasn’t registered them for the plugin market.
Installation instructions for 0.9.7 (Manual)
Notes:
The plugin folder may not exist, so you’ll need to create it.
my-plugi…
koala
December 5, 2021, 10:06am
#3
These docs are a great starting point.
system
closed
December 14, 2021, 6:18am
#4
