A DnD Character sheet I made using Canvas! (complete with working deathsaves counter)
This is a DnD character sheet I made for my current character. It’s designed to be visually striking, user-friendly, and customizable to whatever type of character you play. Made with Canvas and one long CSS snippet. No plugins required (except valentine195’s Dice Roller plugin for the last-minute addition of a 3D rollable hit dice.
GitHub link: https://github.com/epictris/canvas-character-sheet
Features:
  • Visual customization is achieved purely through a CSS snippet
  • Every field is easily editable
  • Non-essential node movement/resizing is disabled to improve UX
  • Image backgrounds expand fluidly as the content inside them grows
  • Functional deathsaves counter (give it a try)
  • Rollable 3D hit dice (thanks valentine195)
This is a prototype, so keep in mind that minimal effort has been made to ensure compatibility with any themes/plugins. Enable this snippet in your own vault at your own risk. (it’s not going to do any damage, but it might temporarily mess with how your other canvases look)
great work
I’ve been playing around with your code, and allow me to say: wow. The implementation isn’t rocket surgery: it’s using the canvas and sprinkling some CSS. But the concept: :exploding_head:
Huge fan of your work, and I’m having loads of fun playing around with the CSS.
Damn, this might be one of the best looking dnd sheets I’ve ever seen. Not sure if it’s something I did, but the rotations just aren’t applying on my end.
I just downloaded this yesterday, and found it horribly broken, due to it being so old. Obsidian has evolved, while the package has not. With the help of the Obsidian Members Group on Discord, I have repaired all of the obvious issues. I even pulled all of the linked images in and made embedded ones, so it’s all local. I also added a community plugin to prevent clicking on the canvas, and creating new blank cards, because I was continually doing that myself.
I’m not really sure what to do with it though, because the original author hasn’t been around. If you’re interested in a version of this that works with current Obsidian, check the “Issues” tab in the official GitHub linked above. If the original author doesn’t respond soon, I’ll try to link my version in there somehow. :slight_smile:
