This is my first post here (but I’ve been lurking for a while) so please be gentle with me ![]()
I’ve been using Obsidian for a bit now, just as a kind of notepad of sorts. Recently, however, I decided to focus my flow so that my research (I’m in academia) can be combined in one place, i.e. Obsidian, hence the Zotero highlight importing.
I’m setting up my Obsidian so that I can import my highlights and notes from Zotero to Obsidian directly. I’ve followed this flow by @FeralFlora with some modifications which you can see below:
{# version: 3.6 -#}
citekey: {{citekey}}
aliases:
- "{%- if creators -%}
{{creators[0].lastName or creators[0].name }}
{%- if creators|length == 2 %} & {{creators[1].lastName or creators[1].name}}{% endif -%}
{%- if creators|length > 2 %} et al.{% endif -%}
{%- endif -%}
{%- if date %} ({{date | format("YYYY")}}){% endif -%}
{%- if shortTitle %} {{shortTitle | safe}} {%- else %} {{title | safe}} {%- endif -%}"{% if itemType == "bookSection" %}
book-title: "{{bookTitle | replace('"',"'")}}"{% endif %}
title: "{{title | replace('"',"'")}}"
{%- set camelRegex = r/([a-z])([A-Z])/g %}
{%- for type, creators in creators | groupby("creatorType") %}
{% if creators.length > 1 %}{{type | replace(camelRegex, "$1 $2") | lower | trim}}:{%- for creator in creators %}{% if creator.name %}
- {{creator.name}}{% else%}
- {{creator.firstName}} {{creator.lastName}} {% endif %}{%- endfor %} {% else -%}
{{type | replace(camelRegex, "$1-$2") | lower | trim}}:{%- for creator in creators %}{% if creator.name %} "{{creator.name}}"{% else%} "{{creator.firstName}} {{creator.lastName}}"{% endif -%}{%- endfor -%}{% endif -%}{% endfor %}
year: {% if date %}{{date | format("YYYY")}}{% endif %}
item-type: {{itemType | replace(camelRegex, "$1 $2") | title | trim}}
publisher: {% if publicationTitle %}"{{publicationTitle}}"{% else %}"{{publisher}}"{% endif %}
{%- if notes.length > 0 -%}
{%- set longShortCutoff = 20 -%}
{%- set shortnotes = [] -%}
{%- set longnotes = [] -%}
{%- for note in notes -%}
{%- if note.note | wordcount <= longShortCutoff -%}
{%- set shortnotes = (shortnotes.push(note.note), shortnotes) -%}
{%- else -%}
{%- set longnotes = (longnotes.push(note), longnotes) -%}
{%- endif -%}{%- endfor -%}{%- endif -%}
{%- for comment in shortnotes %}
{%- if comment and loop.first %}
comments:
{% endif -%}
- "{{comment|replace('"',"'")| replace("\n"," ")}}"{% endfor %}
tags:{% for t in tags %}
- {{t.tag | replace(r/\s+/g, "-")}}{% endfor %}{% if DOI %}
doi: https://doi.org/{{DOI}}{% endif %}{% if itemType == "book" %}
ISBN: {{ISBN}}{% endif %}
cssclasses:
- literature-note{% if attachments.length > 0 %}{% for attachment in attachments %}{% if loop.first %}
attachments:{% endif %}
- {{attachment.path}}{% endfor %}{% endif %}
libraryID: {{libraryID}}
`BUTTON[update-litnote]`
{% persist "notes" -%}
{%- if isFirstImport %}
{# ==The following sections (Key takeaways and Processing) are not filled automatically. They are for for you to write into manually.== -#}
## Key takeaways
{#- The following is a cursor placeholder for the Templater plugin. After importing the note, you can jump to each of these with an assigned hotkey like ctrl+J #}
- <% tp.file.cursor(1) %>
## Processing
- **Status**:: new
- **Connections**:: <% tp.file.cursor(4) %>
- **Projects**::
{% endif %}{% endpersist %}
> [!info]- Info 🔗 [**Zotero**]({{desktopURI}}){% if DOI %} | [**DOI**](https://doi.org/{{DOI}}){% endif %}{% for attachment in attachments | filterby("path", "endswith", ".pdf") %} | [**PDF-{{loop.index}}**](file:///{{attachment.path | replace(" ", "%20")}}){%- endfor %}
>{% if bibliography %}**Bibliography**: {{bibliography|replace("\n","" )}}{% endif %}
> **Authors**:: {% for a in creators %} [[03 - Source notes/People/{{a.firstName}} {{a.lastName}}|{{a.firstName}} {{a.lastName}}]]{% if not loop.last %}, {% endif %}{% endfor %}
> {% if tags %}**Tags**: {% for t in tags %}#{{t.tag | replace(r/\s+/g, "-")}}{% if not loop.last %}, {% endif %}{% endfor %}{% endif %}
> **Collections**:: {% for collection in collections %}[[{{collection.name}}]]{% if not loop.last %}, {% endif %}{% endfor -%}
{%- set readingSpeed = 220 %}
{%- set wordsPerPage = 360 %}
{%- if pages %}
{%- set pageRegex = r/(\d+)\-(\d+)/ %}
{%- set splitPages = pageRegex.test(pages) %}
{%- if splitPages %}
{%- set pageMatch = pageRegex.exec(pages) %}
{%- set firstPage = pageMatch[1] %}
{%- set pageCount = pageMatch[2] - pageMatch[1] %}
{%- else %}
{%- set pageCount = pages %}
{%- endif %}
{%- elif numPages %}
{%- set pageCount = numPages %}
{%- else %}
{%- set pageCount = 0 %}
{% endif -%}
{%- if firstPage %}
> **First-page**:: {{firstPage}}
{%- endif -%}
{%- if pageCount > 0 -%}
{%- set readingTime = ((pageCount* wordsPerPage)/readingSpeed)/60 %}
> **Page-count**:: {{pageCount}}
> **Reading-time**:: {% if readingTime < 1 %}{{(readingTime * 60) | round + " minutes"}}{% else %}{{readingTime | round(3) + " hours"}}{% endif %}{% endif %}
> [!abstract]-
> {% if abstractNote %}
> {{abstractNote|replace("\n","\n>")|striptags(true)|replace("Objectives", "**Objectives**")|replace("Background", "**Background**")|replace("Methodology", "**Methodology**")|replace("Results","**Results**")|replace("Conclusion","**Conclusion**")}}
> {% endif %}
> [!quote]- Citations
> ```query
> content: "@{{citekey}}" -file:@{{citekey}}
{%- set headingRegex = r/^#+/ -%}
{%- set titleRegex = r/^#+.*/ -%}
{%- set lineRegex = r/^.*$/m %}
{%- if longnotes.length > 0 -%}
{%- for n in longnotes -%}
{%- if n and loop.first %}
> [!note]- Zotero notes ({{longnotes.length}})
> Notes longer than {{longShortCutoff}} words.
{%- endif %}
>> [!example]- Note {{loop.index}} |{%- if headingRegex.test(n.note) == true %}[{{n.note | replace(n.note,titleRegex.exec(n.note))|replace(headingRegex,"")}}]({{n.uri}}){% else %} [{{lineRegex.exec(n.note | truncate(30))}}]({{n.uri}})
>> {% endif %}
>> {{n.note | replace("\n", "\n>> ")| replace(titleRegex, "")}}{% if n.tags.length > 0 %}
>> Tags:{% for t in n.tags %} #{{t.tag}}{% if not loop.last %}, {% endif %}{% endfor %}{% endif -%}{%- if not loop.last %}
>{%- endif -%}
{%- endfor -%}{%- endif %}
___
## Reading notes
{% set colorValueMap = {
"#2ea8e5": {
"colorCategory": "Blue",
"heading": "🧠 Thesis",
"symbol": "€"
"#5fb236": {
"colorCategory": "Green",
"heading": "🔑 Key Takeaways",
"symbol": "$"
"#ffd400": {
"colorCategory": "Yellow",
"heading": "🗂️ Evidence and Arguments",
"symbol": "^"
"#f19837": {
"colorCategory": "Orange",
"heading": "✅ Actionable Takeaways",
"symbol": "?"
"#a28ae5": {
"colorCategory": "Purple",
"heading": "💡 Concepts & Frameworks",
"symbol": "~"
"#e56eee": {
"colorCategory": "Magenta",
"heading": "🗺️ Context & Connections",
"symbol": "&"
"#ff6666": {
"colorCategory": "Red",
"heading": "🚧 Digging & Disclaimers",
"symbol": "!"
"#aaaaaa": {
"colorCategory": "Gray",
"heading": "📌 Statistics & Info",
"symbol": "%"
{%- macro tagFormatter(annotation) -%}
{% if annotation.tags -%}
{%- for t in annotation.tags %} #{{ t.tag | replace(r/\s+/g, "-") }}{% if not loop.last %}, {% endif %}{%- endfor %}
{%- endif %}
{%- endmacro -%}
{% persist "annotations" %}
{% set annotations = annotations | filterby("date", "dateafter", lastImportDate) -%}
{% if annotations.length > 0 %}
*Imported on [[{{importDate | format("YYYY-MM-DD")}}]] at {{importDate | format("HH:mm")}}*
{%- set grouped_annotations = annotations | groupby("color") -%}
{%- for color, colorValue in colorValueMap -%}
{%- if color in grouped_annotations -%}
{%- set annotations = grouped_annotations[color] -%}
{%- for annotation in annotations -%}
{%- set citationLink = '[(p. ' ~ annotation.pageLabel ~ ')](' ~ annotation.desktopURI ~ ')' %}
{%- set tagString = tagFormatter(annotation) %}
{%- if annotation and loop.first %}
### {{colorValue.heading}} %% fold %%
{% endif -%}
{%- if annotation.imageRelativePath %}
> [!cite]+ Image {{citationLink}}
> ![[{{annotation.imageRelativePath}}]]{% if annotation.tags %}
> {{tagString}}{% endif %}{%- if (annotation.comment or []).indexOf("todo ") !== -1 %}
> - [ ] **{{annotation.comment | replace("todo ", "")}}**{%- elif annotation.comment %}
> **{{annotation.comment}}**{%- endif %}
{% elif (annotation.comment or []).indexOf("todo ") !== -1 %}
- [ ] **{{annotation.comment | replace("todo ", "")}}**:{% if not annotation.annotatedText %} {{citationLink}}{% else %}
- {{colorValue.symbol}} {{annotation.annotatedText | replace(r/\s+/g, " ")}} {{citationLink}}{{tagString}}{% endif -%}
{% elif annotation.comment %}
- **{{annotation.comment}}**:{% if not annotation.annotatedText %} {{citationLink}}{% else %}
- {{colorValue.symbol}} {{annotation.annotatedText | replace(r/\s+/g, " ") }} {{citationLink}}{{tagString}}{% endif -%}
{%- elif annotation.annotatedText %}
{%- endif -%}{%- endfor %}{%- endif -%}
{% endfor -%}
{% endif %}
{% endpersist %}
Everything works smoothly so far, however, I’d like to edit the template itself to include the following modifications:
- have the note follow the quote pulled from the Zotero highlight, i.e. quote → note, instead of the current note → quote;
- when updating the Update literature note Meta Bind button, I’d like to have the newly imported highlights be appended to the appropriate heading, instead of creating a new one:
- currently, let’s imagine that I have two highlights in Zotero, one blue and one yellow:
- when imported for the first time a new file in Obsidian is created that has both the heading called
Thesis (which corresponds to the blue highlight in Zotero) and the other heading called
Evidence and Arguments headings (corresponding to the yellow highlight), - now, I have made another blue highlight in Zotero (in total two blue, one yellow);
- I hit Update literature note button in the Obsidian note that I’m working on:
- the new highlight is pulled to the note after the
Thesis and
Evidence and Arguments headings, creating a second
Thesis heading containing the new highlight, - what I’d like to happen is for the
Thesis heading to be appended with the second highlight so that after updating the note, it has two highlights from Zotero and
Evidence and Arguments has one.
I have gone and tried tweaking the template as described in [this post](https://forum.obsidian.md/t/zotero-integration-import-templates/36310/79?u=feralflora), however, I can’t seem to get it to work and I don’t have enough coding experience to figure it out on my own.
I’d really really REALLY appreciate your help with editing the template so that both the quote-note order can be changed and that highlights can be appended to the correct heading! Thank you!!!
