Hey, I just tried out this plugin and I’m loving it so far. Enabling a two-way integration between Obsidian and Zotero is fantastic. Great work!
glad to hear :slight_smile: thanks for reporting back
I love this workflow, especially since it appears it can work with most any PDF annotation as well as Zotero’s own beta reader/annotator. However, my ideal workflow would be being able to add annotations to a Zotero PDF (via beta reader and/or from pre-existing, imported annotations), then have all those annotations automatically saved into a destination annotations markdown file (one per PDF, perhaps with an author-date title) within an ‘annotations/’ directory in my Obsidian vault, quotes and pdf page links and all. I could then link to or transclude the MD annotations from any other notes in my vault. If I subsequently added new annotations to the PDF (or removed old ones), those annotations would be automatically added (or removed) to that same annoations MD file in my vault, without breaking any Obsidian links to other annotations in that file. I don’t want to have to think about exporting my annotations or moving them over - I just want to highlight something in a PDF, then know that I can find that highlight in the corresponding MD annotation note.
The Annotator plugin already allows some of this idea (GitHub - elias-sundqvist/obsidian-annotator: A plugin for reading and annotating PDFs and EPUBs in obsidian.) but it’s still in earlier development and having Zotero integration would be amazing.
Does this ideal sound plausible, or even interesting to anyone else? I am not sure if the mdnotes plugin could even do all this or if Zotero itself would need changes. EPUB annotation too would be even better, but I know that ain’t happening :rofl:
Check the bibnotes plugin :slight_smile:
It does not import annotations automatically but it does simplify the process a bit IMO.
You can also update annotations when you make new ones, although there are still a few bugs left.
e.g., updating annotations (syncing with zotero) works but the newly added annotations are added with a missing return line; so you have to add that manually. If you do not, subsequent updates won’t be possible.
You could also comment on this feature request on the zotero forum : [feature-request] Update extracted highlights - Zotero Forums
**I do hope somebody will come up with what you are hoping for :smiley: **
