Installed using “apt install ./obsidian_1.14.4_amd64.deb”. Doing so performed an update from the existing installation which was performed using obsidian_1.13.7_amd64.deb
After changing the zoom level at Settings → Interface → Zoom Level and exiting, the zoom level that I set is not being retained. After restarting the zoom level reverts to the default regardless of what change I make.
Setting wasn’t saved.
Linux (see next field)
Distro Name: Debian
Distro Version: 13 (Trixie)
Desktop Environment: XFCE
Installation method used: apt using the deb file (listed above)
I think that’s all the information?
